Author Topic: SQL to find mult connectors between to elements  (Read 8168 times)
Eamonn John Casey
« on: January 10, 2018, 11:04:40 pm »
Hi!
Does anyone want to share a nifty SQL that finds more than one Connector between to elements? Using "Hide Connector" and similar functionality has been a complete disaster for us. There are some pairs of elements in our model that have many connectors btween them. Makes creating New diagrams labourous to hide unnecessary eones.
I know the tables involved but not really a SQL guru!
Eamonn J.
Re: SQL to find mult connectors between to elements
« Reply #1 on: January 10, 2018, 11:51:39 pm »
try this:
select os.ea_guid AS CLASSGUID, os.Object_Type AS CLASSTYPE, os.Name as SourceObject, os.ea_guid as SourceGUID,
c.Connector_Type as ConnectorType, ot.Name as TargetName, ot.ea_guid as targetGUID, count(*)
from ((t_connector c
inner join t_object os on os.Object_ID = c.Start_Object_ID)
inner join t_object ot on ot.Object_ID = c.End_Object_ID)
group by os.ea_guid , os.Object_Type , os.Name , os.ea_guid , c.Connector_Type , ot.Name , ot.ea_guid
having count(*) > 1
order by count(*) desc
« Reply #2 on: January 11, 2018, 12:29:50 am »
That will output all elements with more than one connector. I guess the OP is after a list of connectors for two distinct element?
« Reply #3 on: January 11, 2018, 12:45:11 am »
No it won't, see the grouping.
It will output all element/connector details for all elements that have 2 or more of the same kind of connector to the same element (which makes them a candidate for duplicate connectors, although there might be valid exceptions)
Eamonn John Casey
« Reply #4 on: January 11, 2018, 01:32:28 am »
Thanks! I now got a start point to tweek With.
The scenario I am looking for is (using ArchiMate speak):
A is Assocaited With B
B is Serving A
So I am looking for Connectors in both directions and of same or different types. I'll post the result when I get to it.  :)
/ Eamonn J. //
« Reply #5 on: January 11, 2018, 10:40:11 am »
Candidacy is relatively easy.  Actually determining whether two connectors are semantically the same (and perhaps consolidating properties that are not semantically significant) is non-trivial.  We have a version which we are testing as part of our element consolidation process.
