Author Topic: Repository.Models.Refresh()  (Read 6538 times)
BruceTOGAF2
« on: January 12, 2018, 08:57:30 pm »
I have seen comments on this forum like "Repository.Models.Refresh() doesn't work".  In my experience it did work an other scripts but not in my current Jscript project.
My Jscript imports a word document into Sparx packages and Artifacts.  Each time I create a new package, I update the Package.TreePos with an incremental counter so that packages are sequenced correctly.  After the MS-Word document has been imported, I execute Repository.Models.Refresh(), but it is seemingly being ignored. Nothing changes.
If I close the Sparx project and re-open the project file, only then I can see the packages in the correct sequence as per Package.TreePos.
Why is Repository.Models.Refresh() failing?
Re: Repository.Models.Refresh()
« Reply #1 on: January 12, 2018, 09:28:03 pm »
Could it be that you have mixed up Repository.Models.Refresh() with Repository.RefreshModelView()
I think the latter is the one you need to reflect changes in the order of packages in the project browser.
BruceTOGAF2
« Reply #2 on: January 12, 2018, 09:37:39 pm »
Hi Geert,
I also tried Repository.RefreshModelView()
I got error "Argument not optional"
« Reply #3 on: January 12, 2018, 10:55:42 pm »
you have to pass the package ID. Use "0" for whole model.
BruceTOGAF2
« Reply #4 on: January 12, 2018, 11:43:44 pm »
Thank you Geert.  I am very pleased with this development and with your help, so I will post the complete Jscript code in a new topic.
Import Word document into Sparx nested packages
Good idea?
