Author Topic: Open the Relationship Matrix via script  (Read 8881 times)
OpenIT Solutions
« on: January 12, 2018, 11:36:36 pm »
Is there a way to open the Relationship Matrix via a script ? Ideally also set the 'profile' and/or source and targets ?
Jon.
VKN
Re: Open the Relationship Matrix via script
« Reply #1 on: January 15, 2018, 09:42:57 am »
Look for Matrix Specification Artifact in the below link. Then maybe you can apply a double click to open the Matrix with the predefined profile.
http://www.sparxsystems.com/enterprise_architect_user_guide/13.5/modeling_tools/artifacttbp.html
« Reply #2 on: January 17, 2018, 03:24:45 pm »
Jon.
Hi OpenIT Solutions
There isn't any direct API calls to open the relationship matrix via scripts.
You can create a Matrix profile (as suggested VKN ) using an API and it might do the trick  ;).
After you create the Profile definition, each time you double-click on the Artifact element the Relationship Matrix displays with the Profile applied.
Please refer http://sparxsystems.com/enterprise_architect_user_guide/13.5/model_navigation/elementrelationshipmatrix.htmlfor more details
OpenIT Solutions
« Reply #3 on: January 17, 2018, 07:57:51 pm »
What I'm really after is a way via a script. I think I remember sometime ago reading that there were some undocumented features that could be used to simulate a menu/ribbon click via script. I can't find the thread on the group however. Ring any bells with anyone ?
Jon.
« Reply #4 on: January 17, 2018, 08:24:42 pm »
You can, but prepare to get dirty -> simulating mouseclicks and keypresses  :o
One the examples I found here: http://www.sparxsystems.com/forums/smf/index.php/topic,4363.msg120072.html#msg120072
« Reply #5 on: January 17, 2018, 08:25:20 pm »
You're after Respository.CustomCommand. It might have some parameter, but I'm not aware of one for the RM.
iBro_97
« Reply #6 on: February 28, 2023, 06:07:35 am »
have you been able to solve your problem? Are there any new commands, to trigger an export of a relationship matrix with a pre defined matrix profile.
I'm facing the exact same task.
thank you and regards,
Ibro
