Author Topic: Reverse Engineering a MySql db (RDS on AWS)  (Read 7181 times)
tabevetts
« on: January 17, 2018, 10:18:00 am »
I have setup an ODBC datasource and can access it via the ODBC Administrator, but when I attempt to reverse engineer it to EA, it errors off with;
"Data source name not found and no default driver specified"?????
hd
Re: Reverse Engineering a MySql db (RDS on AWS)
« Reply #1 on: January 17, 2018, 12:42:33 pm »
Are you using the 32-bit MySQL ODB Driver?  See the first Note at the bottom of page...
http://www.sparxsystems.com/enterprise_architect_user_guide/13.5/model_domains/importdatabaseschemafromod.html
« Reply #2 on: January 17, 2018, 03:35:34 pm »
Hi Tabevetts
If error occurs even after checking what hd suggested please check the below points.
  • Check whether its created in User DSN or Syatem DSN
  • Check the driver name , instead of DRIVER={MySQL ODBC 5.3 Driver} try DRIVER={MySQL ODBC 5.3 Unicode Driver} you can see the name of the driver from administration tool
