Author Topic: Changes in quick linkers require EA restart?  (Read 6717 times)
DanielB
« on: January 18, 2018, 09:28:02 pm »
Is it true, that changes in quick linkers require application restart? I found this the only way to have them working, but it's extremely convenient to say the least. Is there any attribute to be switched on to change this?
Daniel
Re: Changes in quick linkers require EA restart?
« Reply #1 on: January 18, 2018, 09:32:50 pm »
Hi DanielB
Yes a restart is required for MDG quicklinkers to get updated in repository.
Unfortunately there isn't any option for it  :( :(.
« Last Edit: January 18, 2018, 09:35:44 pm by EAUser3200 »
« Reply #2 on: January 19, 2018, 12:12:27 am »
Then why complaining?  ;D
« Reply #3 on: January 19, 2018, 10:53:48 am »
Hi Daniel,
I haven't checked for QuickLinker, but for other elements of the MDG, we don't have to restart EA to get the updated MDG installed.  The QuickLinker is a global structure (to which each MDG supplies a portion), so I suspect that it is not possible to unload the existing QuickLinker for a specific MDG (probably because each entry is NOT tagged with the MDG(s) that provided it).  Hence a restart is required.  You can append (as you load MDGs dynamically), but you can't remove.
