Author Topic: Adding Tags via Javascript  (Read 8805 times)
hofzge
« on: January 25, 2018, 12:08:07 am »
When I try to tag elements in a model I get this problem:
Error
Test Scripts.AliasToTag
currentElement.TaggedValues is undefined, Line: 115
This error occurs when I try to tag the elements:
var currentElement as EA.Element;
currentElement = theElement;
var taggedValue as EA.TaggedValue;
taggedValue = null;
if(currentElement != null)
// Output the current element's name and alias
Session.Output(indent + "Element=" + currentElement.Name + ", Type=" + currentElement.Type + ", Alias=" + currentElement.Alias);
        taggedValue = currentElement.TaggedValues.AddNew(taggedValueName, taggedValueValue);
currentElement.TaggedValues.Refresh();
taggedValue.Update();
in this line:
Nabil
    • View My LinkedIn Profile Here
Re: Adding Tags via Javascript
« Reply #1 on: January 25, 2018, 12:15:59 am »
Try commenting the below lines and say are you getting session output value?
[/quote]
[/quote]
Refer LocalScripts -> Element Extras Example
// Add a new tag
      var tags as EA.Collection;
      tags = theElement.TaggedValues;
      var newTag as EA.TaggedValue;
      newTag = tags.AddNew( "MyTag", "Number" );
      newTag.Update();
      tags.Refresh();
Nabil
hofzge
« Reply #2 on: January 25, 2018, 12:38:23 am »
I tried to do it that way and added this:
tags = currentElement.TaggedValues;
newTag = tags.AddNew(taggedValueName, taggedValueValue);
Now I get a similar error in your code:
Error
tags is undefined, Line: 106
which is this line:
The reason must be somewhere else...
« Reply #3 on: January 25, 2018, 12:38:40 am »
Where is
theElement coming from?
This variable is probably not holding an object of type EA.Element
hofzge
« Reply #4 on: January 25, 2018, 12:54:40 am »
function SetElementTaggedValue(indent, theElement, taggedValueName, taggedValueValue)
and it is called like this:
var childElementEnumerator = new Enumerator(currentElement.Elements);
// Tag the current element with its alias
SetElementTaggedValue(indent, currentElement, "old_ID", currentElement.Alias);
« Last Edit: January 25, 2018, 01:02:10 am by hofzge »
« Reply #5 on: January 25, 2018, 01:11:00 am »
I'm still not seeing you initialize "theElement".
If you don't initialize the variable then it will have a null value (and null.TaggedValues.AddNew() won't work)
Nizam
  • Prolab Moderator
  • Model Sharing - Simplified
« Reply #6 on: January 25, 2018, 01:17:11 am »
I guess you are passing theElement, which could be from GetTreeSelectedObject or similar. These functions may not always return a value.
add if ( theElement != null) condition and see if it goes through.
hofzge
« Reply #7 on: January 25, 2018, 01:40:04 am »
I think that is what happened:
I initialize it like this:
rootElement= Repository.GetTreeSelectedObject();
DumpElements("", rootElement);
and it seems this sometimes does not work and I get null. After checking if the tags exist it runs through:
if(tags!=null){
Thanks to all the answers. I was not aware the getTreeSelectedObject was this dangerous.
« Reply #8 on: January 25, 2018, 02:18:35 am »
It's not really dangerous, but have to test what it returns. Depending on what you actually selected in the project browser it could any of EA.Package, EA.Diagram, EA.Attribute, EA.Operation, EA.Element or even null (if you haven't selected anything at all in the project browser)
You can't assume it will return an EA.Element
