Author Topic: Inconsistent behavior of diagram query results created with Query Builder vs SQL  (Read 8513 times)
PeterHeintz
When defining queries of diagrams with the Query Builder, each row of the returned results shows the right diagram type icon and double click to a row opens the diagram.
When you do the same with SQL and using t_diagram.ea_guid as CLASSGUID and t_diagram.Diagram_type as CLASSTYPE the wrong icon is shown and double click does not work. Double click starts opening the right diagram after a “Find in Project Browser” is done row per row.
Further information:
http://www.sparxsystems.com/forums/smf/index.php/topic,39165.0.html
Best regards,
Peter Heintz
You know that an official bug report need to be sent via the link down below in the support section?
PeterHeintz
Yes, ticket is submitted. However in the ticket I point to this issue to make it public.
Best regards,
Peter Heintz
Paolo just notes "reported" at the end. So everyone knows it's on rails.
Well, I found why you can't use t_diagram.diagram_type: It might return "Activity" and this will show the Activity icon. Anyhow, if there's no easy solution to show the diagram icon, it would be ok (I guess) to just show a common diagram icon with
"Diagram" as CLASSTYPE or the like.
PeterHeintz
Thank you!
I will try something like this.
However my key feature I am looking to, is having the double click opening the diagram directly.
Basically I want to get rid of my huge amount of queries, by one, and adding the different diagram set types types in the <Search Term> like ‘Use Case’, ‘Test Case,..
I tried it with the Query Builder but I did not find a solution. Maybe you have an idea on having a type list in <Search Terms>.
Best regards,
Peter Heintz
Except for using a smart add-in I'd have no idea. Paolo (IIRC) asked for more flexibility in the input of a search (like to have more than one input field). I guess a "real" smart solution is something you can't expect from down-under. Most times it's like "Oh, I have a nice hammer here. Let's see how we can use it for cooking."
PeterHeintz
Yes, I remember to have voted for that Paolo issue.
In principle all what I need is there and there are several options that could do that, but each option has an other problem.
So just another “disregarded or off-limits flaw” (doof). :'(
Best regards,
Peter Heintz
Almost.
Use 't_diagram' as CLASSTABLE.
See the built in Recently Modified Diagrams search for an example.
That was a quick one. I assume a mixed display of elements and diagrams would not be possible?
PeterHeintz
Thank you Simon,
t_diagram' as CLASSTABLE makes all work.
I suggest that you also consider that magic thing in the user manual.
Best regards,
Peter Heintz
I thought it was, but the only reference to it in the current version of the manual is for connector types. (Which also share type names with t_object)
