Author Topic: VBScript Excel formatting cells undefined Excel constant  (Read 6903 times)
yaccoff
« on: January 28, 2018, 01:36:12 am »
Hi there,
Using a VBScript i am writing an SQL query of the DB and exporting the output to Excel
set oExcel = CreateObject ("Excel.Application")
With the active workbook selected I want to format the header row, but the use of xlSolid xlCentre,etc generates an error 'undefined variable' Is there something I can import to access xlSolid?
With oWorksheet.Cells.Rows(1)
         .Font.Bold = True
         .Font.Name = "Calibra"
         .Font.Size = 11
'         .Interior.Pattern = xlSolid
         .Interior.Color = 15773696
         .HorizontalAlignment = xlCenter
         .VerticalAlignment = xlCenter
         .WrapText = False
         .Orientation = 0
         .AddIndent = False
         .IndentLevel = 0
         .ShrinkToFit = False
         .ReadingOrder = xlContext
         .MergeCells = False
End With
« Last Edit: January 28, 2018, 02:29:11 am by yaccoff »
Re: VBScript Excel formatting cells undefined Excel constant
« Reply #1 on: January 28, 2018, 02:33:40 am »
Note that this is a help place for EA issues, not for Excel. You should ask the guys at StackOverflow.
yaccoff
« Reply #2 on: January 28, 2018, 03:51:50 am »
Hi there, I thought about that, but its not an Excel question. Under standard VB I wouldn't need to provide anything to access xlSolid, as it would be in the environment. So really I want to know if the EA has a !INC that would provide xlSolid, etc.
yaccoff
« Reply #3 on: January 28, 2018, 03:59:57 am »
As an interim step incase there isny any !INC I replace the xlSolid enum with its actual value from
https://msdn.microsoft.com/en-us/vba/excel-vba/articles/constants-enumeration-excel
« Reply #4 on: January 29, 2018, 03:39:23 pm »
Yaccoff,
You are not using VB, but VBScript. And regardless of EA, VBScript won't know about constants define by Excel or any other library.
All you can do is define the constants yourself in a similar way as Local Scripts.EAConstants-VBScript
