Author Topic: Auto-numbering based on stereotype  (Read 5369 times)
etaha
« on: January 30, 2018, 09:07:30 am »
Is there a add-in to define auto-numbering rules for elements based on their stereotypes?
Thanks in Advance
Re: Auto-numbering based on stereotype
« Reply #1 on: January 30, 2018, 09:48:45 am »
Maybe. But there's no market place for such things. You can define auto-numbers in EA, but it's a bit limited (Project/Settings/Auto...).
Helmut Ortmann
« Reply #2 on: January 30, 2018, 06:13:13 pm »
the open source hoTools supports auto numbering for arbitrary types and stereotypes. See: https://github.com/Helmut-Ortmann/EnterpriseArchitect_hoTools/wiki/AutoNumber
Best regards,
Helmut
etaha
« Reply #3 on: January 30, 2018, 07:02:27 pm »
Thank you all
etaha
« Reply #4 on: January 30, 2018, 11:25:57 pm »
@Helmut Ortmann, Thanks a lot. Great tool and works like a charm.
For Drag and Drop functionality it works only for default stereotypes defined in EA, for example NonFunctionalRequirements, but Drag and Drop will not work for non-default stereotype such as <HighLevel>Requirement because it stereotype is changed to HighLevel after element creation.
Using the Specs menu to apply for all model, it works but this require run it each time a new requirement with that specific stereotype is added.
Is there a way to handle this for example
- Define MDG for requirements with specific stereotype
- Set keyboard shortcut to run Spec Auto Name commands
Thanks a lot for great efforts
