Author Topic: SQL-based report on package info coming up empty  (Read 7172 times)
bknoth2
« on: February 01, 2018, 05:11:48 am »
EA Version 13.5.1352
1) I use an SQL search to find a package by name. I know the search works - I can right click a returned package and the "Find in browser" feature is highlighted and works.
2) I have a document template that reports the package name and notes. I can generate that document directly from a package (by right-clicking the browser) and the contents are correct in the generated report.
When I create a "Model Document" and specify the search and name from 1) above and the template from 2) and then generate the report, the report comes up empty. The package name and notes don't appear. (If I include elements and the element names, I see a correct list of element names in the report so I know the report receives the package information but no package information appears). Any ideas?
Bruce
Nizam
  • Prolab Moderator
  • Model Sharing - Simplified
Re: SQL-based report on package info coming up empty
« Reply #1 on: February 01, 2018, 02:05:36 pm »
Notes for User Guide:
Diagram Searches are not supported
Custom SQL searches are supported if they are returning elements; the SQL must include ea_guid AS CLASSGUID (case sensitive) and the object type
bknoth2
« Reply #2 on: February 02, 2018, 03:16:19 am »
Everything I described was to find and report on the notes for a package listed in the project browser, not in a diagram.
Thanks for replying,
Bruce
Aaron B
« Reply #3 on: February 02, 2018, 10:14:12 am »
Hi Bruce,
Can you provide the contents of your SQL Search definition?
Nizam
  • Prolab Moderator
« Reply #4 on: February 02, 2018, 03:39:45 pm »
Bruce
These are notes from EA User Guide,
I was also trying to highlight that you've to include 'ea_guid AS CLASSGUID' in your query.
I used the query below, and was able to report on the results without any issues ( i just used one of the default template, Model Report)
select ea_guid AS CLASSGUID, Name from t_package where t_package.Name Like "Chapter*"
bknoth2
« Reply #5 on: February 10, 2018, 12:18:56 pm »
select t_package.Name, t_package.Package_ID, 'Package' AS CLASSTYPE, t_package.ea_guid AS CLASSGUID from t_package where t_package.Name like '<Search Term>'
Now what I get in my document is the target package plus the parent package plus the only sibling of my target package. When I run the search as a search, only my target package is returned (as expected).
Bruce
