Author Topic: Using a central local help library  (Read 5420 times)
Eamonn John Casey
« on: February 01, 2018, 08:47:14 pm »
Is there any way in EA 13.5 to point to a Central help file? Our users run in a secure environment With no internet Access and no permissions to install software. Software gets pushed out to Virtual machines and I do not want to replicate help system for Our user base.
Eamonn J.
Re: Using a central local help library
« Reply #1 on: February 01, 2018, 08:53:49 pm »
Uffe
« Reply #2 on: February 01, 2018, 10:59:32 pm »
I did a quick scan through the registry on a virtual machine where I have the user guide installed, but unfortunately I couldn't find a key that holds its install location.
Maybe you could install the user guide on a central file share and make     C:\Program Files (x86)\Sparx Systems\User Guide\     a shortcut to that? Not sure if that would work, but it might.
/Uffe
« Reply #3 on: February 02, 2018, 09:01:46 am »
There is a path in the registry.
I don't have it installed right now, but think you'll find it in HKLM/Software/Wow6432Node/Sparx Systems.
Uffe
« Reply #4 on: February 02, 2018, 07:34:29 pm »
Yup, that's it.
Key         HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Sparx Systems\UserGuide
Value Name  Path
Value Data  C:\Program Files (x86)\Sparx Systems\User Guide\
I did a simple test moving the guide to a different directory on a local hard drive, and it worked. I didn't try it with a UNC path, so that's probably worth a quick check before you deploy.
/U
Eamonn John Casey
« Reply #5 on: February 03, 2018, 01:13:55 am »
Hei,
Thanks for replies. Was able to move Help System to an alternative location on the network that is mapped up on login. So that Works fine.
I am going to try out hosting it on Internation Server.  ;D
