Author Topic: A bug nesting  (Read 5377 times)
dimMF
A bug nesting
« on: February 05, 2018, 11:00:27 pm »
Hi everyone.
Was found is some feature or bug.
There's a package (level 1) 500 groups of objects (level 2) in each of which several objects (level 3). In ORA database SPARX all the data fine but in the client not all the objects are in level 3 and displayed in 2 level.
Is this normal?  :o
ps. Data insert by script.
dimMF
Re: A bug nesting
« Reply #1 on: February 05, 2018, 11:02:29 pm »
Looks like a limitation of the interface can not be more than the number of objects nested into a single folder.
Re: A bug nesting
« Reply #2 on: February 06, 2018, 12:02:03 am »
Have yo tried closing and opening the project?
Changes to the model structure done in the backend often don't show up immediately.
I've never seen any kind of limitation in the GUI. If it was not showing some elements, that I could understand, but showing it at the wrong "level" seems really arbitrary.
PS. 500 objects in a single package does not seem like a good idea to me in any scenario. ??? Any chance you can split those up into different packages?
dimMF
Re: A bug nesting
« Reply #3 on: February 06, 2018, 12:33:55 am »
Yes, i try, reopen and reconnect to oracle. Dont help.
In t_object table i check problem elements object level3 have correct parrent_id level2 but in GUI he in level1 this is very strange. In this case not all object set in lvl 1 someone place correct.
We have 50+ systems, 500+ nodes with reserv and 3000+ servers, and have idia to drow system diagrams automaticly. I try to build registry of nodes with servers. Maybe i must create 2 registry nodes and servers with links?
