Author Topic: Layout diagram automatically upside down  (Read 5113 times)
Markus Rohner
« on: February 08, 2018, 02:07:48 am »
I'm creating a new diagram
EA.Diagram collaborationDiagram = collabModel.Diagrams.AddNew(JobChainName, "BPMN2.0::BusinessProcess");
and then add activities to it
EA.Collection diagramObjects = collaborationDiagram.DiagramObjects;
EA.DiagramObject collabDiagramObject = diagramObjects.AddNew("l=200;r=600;t=200;b=200;", "");
collabDiagramObject.ElementID = activity1.ElementID;
collabDiagramObject.ElementID = activity2.ElementID;
and connect them as type "ControlFlow"
After adding start end end event (connected too) I layout the diagram:
Model.GetProjectInterface().LayoutDiagramEx(collaborationDiagram.DiagramGUID,0,4,20,20,true);
So far so good. The code works. Everything is on the diagram BUT it get's layouted updside down.
The start event is at the bottom and the Flow goes upward (the arrows are pointing upwards) and on top of the page there is the end event.
This happens aswell when I draw a collaboration diagram in EA an press <Diagram Layout: Apply Default Layout>.
So I don't think that the code is wrong.
I thought to lay it out manually. That's much more complicated and I couldn't find out what ("l=200;r=600;t=200;b=200;", "") means.
Does someone know how to do it correctly?
Thanks.
Markus
Re: Layout diagram automatically upside down
« Reply #1 on: February 08, 2018, 02:58:23 am »
Thanks.
Markus
Hi Markus
Its the position of the object in the diagram.
You can even set it directly in the DiagramObject property.
collabDiagramObject .left
collabDiagramObject .right
collabDiagramObject .bottom
collabDiagramObject .top
« Reply #2 on: February 08, 2018, 02:59:32 am »
Check out the documentation in the manual:
http://www.sparxsystems.com/enterprise_architect_user_guide/13.5/automation/project_2.html
With the LayoutStyle parameter you can control the layout.
Also worth looking is the settings for the layout style.
Go to diagram properties | Diagram | Set Layout Style.
That dialog also includes a checkbox to use that style as the default style for the whole repository.
Markus Rohner
« Reply #3 on: February 08, 2018, 05:47:52 pm »
 8) Thanks a lot to both of you.
It works now, I knew I missed something...
Markus
