Author Topic: Link an User Interface element to Table/Column  (Read 9852 times)
Miso2018
« on: February 09, 2018, 07:42:52 am »
I need to show a link between an User Interface element and a Table (specifically link to a Column). The Tables (with Columns) have been successfully imported from SQL Server.  Could someone suggest how to create a diagram showing links from the UI fields to the Table/Columns please
Re: Link an User Interface element to Table/Column
« Reply #1 on: February 09, 2018, 11:24:42 am »
Hi Miso,
Look up "Link to element feature" in the help.
We use it all the time to link a feature to another.
Miso2018
« Reply #2 on: February 09, 2018, 11:41:42 am »
Great, it works! Your prompt help is much appreciated Paolo.
Miso2018
« Reply #3 on: February 15, 2018, 08:43:26 am »
hmmm,  ... I'm somewhat embarrassed but have to ask for help again. Why the "Link to Element Feature" option is not on the menu when I right-click on the end of connector/relationship? It was there when I tried initially but not now! Is there anything to do with the new Diagram or connectors properties?
« Reply #4 on: February 15, 2018, 09:11:05 am »
It won't be available for all connector types. For example, I wouldn't expect to see it for generalization, state transition, control flow, note link, ...
Miso2018
« Reply #5 on: February 15, 2018, 09:20:01 am »
I tried it on all available connectors for UI element to Table (Inf Flow, Trace, Dependency, Realization)
« Reply #6 on: February 15, 2018, 10:02:16 am »
I just tried it on all four of those and it was available, as long as you right-click close to the end of the connector (EA 13.5.1352)
VKN
« Reply #7 on: February 15, 2018, 10:07:54 am »
If you right click at the center of the connector, the menu item will not appear. Try right clicking on the connector closer (say 25%) to the element.
RoyC
  • Read The Help!
« Reply #8 on: February 15, 2018, 10:53:37 am »
The reason being: the system needs to know which element you are selecting the feature in - the target or the source.
Best Regards, Roy
Miso2018
« Reply #9 on: February 15, 2018, 11:55:48 am »
Thanks guys for your help. Now I know that my problem was caused by me trying to R-click on the small square which become visible when the connector was selected (instead close to it).
