Author Topic: Shape Script: Attribute visibility when using non rectangular UML  (Read 4918 times)
Gus Gunn
If I create a shape script and use the image method to replace the standard rectangular notation is there a way I can get the attribute compartment to display using AddCompartmentText for example?
Re: Shape Script: Attribute visibility when using non rectangular UML
« Reply #1 on: February 13, 2018, 02:46:18 pm »
Hi Gus
Its not possible to show the attributes compartment in diagram if  with an image.
« Last Edit: February 13, 2018, 05:15:28 pm by Arshad »
« Reply #2 on: February 13, 2018, 04:55:24 pm »
Hi Gus
Its not possible to show the attributes compartment in diagram if you replaced it with an image.
Without image , you use AddCompartmentText to make attributes visible in shape scripts.
No, you can't show attribute information using AppendCompartmentText in a shape script. It's used in either a shape RelatedElement which is called once for each connector attached to the element, or shape ChildElement which is called once for each owned element. There is no shape that iterates the owned attributes.
« Reply #3 on: February 13, 2018, 05:15:02 pm »
Yes Kp.
thats my mistake , updated the answer.
Thanks for the note.
