Author Topic: Adding checklist tagged value to profile stereotype  (Read 6117 times)
DanielB
« on: February 13, 2018, 10:29:18 pm »
I've added Enumeration class as a new tagged value to my custom stereotype in an MDG I'm creating. How do I make this tagged value a checkilst (multiple selection) instead of single select? Should I change the type of Tag?
At the moment it looks like this in an XML file:
<Tag name="NAME" type="enumeration" description="" unit="" values="A,B,C" default="A"/>
Thank you in advance.
Daniel
« Last Edit: February 14, 2018, 12:21:02 am by DanielB »
Re: Adding checklist tagged value to profile stereotype
« Reply #1 on: February 13, 2018, 10:39:25 pm »
Hi Daniel
 For checklist please try
Type=CheckList;
Values=Val1,Val2,Val3;
Please define your own tagged value with checklist type and add it in the stereotype.
To Create tagged value from pre defined type
http://www.sparxsystems.com/enterprise_architect_user_guide/10/extending_uml_models/create_tagged_values.html
For more details please refer Predefined Types
http://www.sparxsystems.com/enterprise_architect_user_guide/10/extending_uml_models/predefinedtaggedvaluetypes.html
« Last Edit: February 13, 2018, 10:43:12 pm by Arshad »
DanielB
« Reply #2 on: February 13, 2018, 10:48:50 pm »
I had tried this before posting a thread but it didn't seem to work:
<TaggedValues>
  <Tag name="NAME" type="CheckList" description="" unit="" values="A,B,C" default="A"/>
</TaggedValues>
still single selection.
« Last Edit: February 14, 2018, 12:20:37 am by DanielB »
« Reply #3 on: February 14, 2018, 11:56:53 am »
<TaggedValues>
</TaggedValues>
Hi Daniel,
If you started off with a single selection enumeration and now want a (simple) multiselection set then a type CheckList is NOT what you need.  EA implements a CheckList as a TRUE Checklist (I got "sucked in" the same way).  Re-read the definition referenced by Archad.  IIRC there is currently no mechanism to create a multiselection set.
In addition, IIRC there are issues with the current implementation of CheckList.  I posted a topic about it within the last year, I think.
