Author Topic: Popup Dialog when Profile element is used  (Read 3232 times)
lario
« on: December 06, 2011, 09:10:59 am »
I have a profile that has a stereotype <Uses> that extends <Realization> meta class.  When <Uses> is used between two classes, I want to popup a menu of the attributes that are present in parent class.  Is this possible? Can you direct me to where I may learn more?
Re: Popup Dialog when Profile element is used
« Reply #1 on: December 06, 2011, 08:18:37 pm »
Not sure if that's what you want, but look up Quick Linker in the help. You can modify the behaviour of the popup via a csv-formatted table.
