Author Topic: Best practice to create documentation?  (Read 5888 times)
Hurra
    • Find me at LinkedIn!
« on: February 20, 2018, 09:21:36 pm »
Hello!
I have worked quite a bit with document generation and know the basics of templates, fragments, custom scripts, document scripts etc.
When I create a document generator I usually use a simple SQL search as basis, either GUID/ID or name (if I'm sure there is no duplicates). However, I was thinking, when I set up a document generator for let's say, requirement specification. I want to use that document generator for different IT-system/applications, e.g. make instances.
Should I use the doc gen I created and just change the SQL search values? Should I duplicate the doc gen? Should I connect one more Document Artifact? Is there any best practice, or how do you guys do this?
Robert.
always learning!
Hurra
always learning!
