Author Topic: Not enough storage is available to complete this operation  (Read 5077 times)
ngong
« on: February 20, 2018, 10:31:46 pm »
I am using EA together with PTC.
Prior to checking out, I used to "Get All Latest" in "Package Control", in order to have all latest changes available.
Sometimes - most probably at times when I have worked some time with EA e.g. on other projects - I get the failure
"Error: Code=0x8007000e Souce=Line:0;Char:0 Error Description=Not enough storage is available to complete this operation."
The only way I found to get out of this problem - other error windows pop up when I close it - is, to kill the EA process using Task Manager.
It does not help to restart EA, but to restart Windows.
Sometimes after restarting, EA tells, that there is some data base problem an I have to repair the eap file.
I am using Win7 with 16GByte, Task Manager Performance show less the 8GByte have been used.
Any advice to avoid this problem (looks like a memory leak somewhere).
Kind Regards
Rolf
Rolf
Glassboy
Re: Not enough storage is available to complete this operation
« Reply #1 on: February 21, 2018, 10:17:38 am »
Given both issues you're having I recommend starting by running a check disk and maybe using Bleachbit to clean out all the cruft.
ngong
« Reply #2 on: June 13, 2018, 06:06:50 pm »
Thank you Glassboy for your suggestion.
However, it does not help much and it happens on computers of several colleagues as well.
My current solution is to stay away fram any .eap file issuing deep and not understandable failure messages.
I created an empty template .eap file that is connected to PTC. Making a copy of it and do "Get All Latest" for a clean and refreshed .eap file.
I also stay away from using "repair" or "compress" as I lost dependencies between packages.
I know that I have not investigate the problems deeply to a proper result. But the effects are that divers, it is beyond my abilities. I wonder wether we are the only project with such problems with the default database an .eap file is using.
« Last Edit: June 13, 2018, 06:24:31 pm by ngong »
Rolf
