Author Topic: How create Forms for editing element attributes  (Read 7321 times)
steen.jensen
« on: February 21, 2018, 09:14:43 am »
How do I (easy) create forms for editing selected fields (Notes, Tagged values etc) without a lot of clicking around EA standard GUI?
I have seen a form when using HL7 FM2 model that was having its own profile
Hurra
    • Find me at LinkedIn!
Re: How create Forms for editing element attributes
« Reply #1 on: February 21, 2018, 05:30:26 pm »
Using a SQL query is one solution I guess.
always learning!
« Reply #2 on: February 21, 2018, 05:52:39 pm »
Two choices basically
- Try EAForms, an add-in specifically aimed at this
- Write your own add-in (which is what I would do)
Hurra
« Reply #3 on: February 21, 2018, 07:33:11 pm »
ofc you would write your own add-in, because you're really good at it  ;)
always learning!
« Reply #4 on: February 21, 2018, 07:47:02 pm »
Thanks ;) I guess practice makes perfect  :)
steen.jensen
« Reply #5 on: February 21, 2018, 09:46:31 pm »
Okey, thanks I check EAforms, Making my own MDG is a looong way ahead :)
« Reply #6 on: February 21, 2018, 10:03:17 pm »
Hi Steen
Have you tried Work Space Layout option.
Please have a look at it before going for any custom forms for just .
You can Create and use a new layout with notes and tagged values dock enabled.
Most of the elements attributes can be docked in the work space.
« Last Edit: February 21, 2018, 10:05:50 pm by Arshad »
