Author Topic: Project differences/changes  (Read 4740 times)
exsypher
« on: February 21, 2018, 10:50:38 pm »
is there a way to check which changes were made to a project? I found the Project Compare function but that lists only which tables has been changed. Isnt there some way to check differences between two projects in detail?
Kind regards
ex
Re: Project differences/changes
« Reply #1 on: February 21, 2018, 10:56:42 pm »
Hi ex
If you already taken a baseline of the project then you can compare it with the latest project and identify the changes.
It will give the full list of changes and also you can revert the changes from baseline.
« Last Edit: February 21, 2018, 11:06:49 pm by Arshad »
Helmut Ortmann
« Reply #2 on: February 24, 2018, 08:16:10 pm »
if you want to know solutions for even complex environments have a look on LemonTree from LieberLieber.
It's more than just compare two release and I know companies who successfully use LemonTree for version control.
Best regards,
Helmut
