Author Topic: Possible to get Site-IDs (i.e. EA1/EA2/EA3.htm) out of the eap-database (SQL)?  (Read 4569 times)
Schludi
Hello Community!
I have the Object-Name/Object-Alias for an exported HTML-Site/EA-Object and want to get the link like:
.../EARoot/EA3/EA3/EA3/EA2/EA834.htm
out of the database by name.
What I need is a function like this, that gets from the SQL-EAP-File (MDB) the link.
url getLinkForSiteAlias(string sitealias) {... return sitealias}
or
url getLinkForSiteName(string sitename) {... return sitename;}
Is it somehow possible to get the generated filepath from the SQL?
You can get stable url's using the GUID.
Schludi
Hi Geert!
Is it possible to use the GUID to link to an HTML Export Element?
Greets Björn
Uffe
Hej!
Try https://example.com/Generated_EA_Stuff/index.html?guid={xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx}
This works for diagrams too, if you want to link to your generated HTML from another page.
Just be aware that while GUIDs obviously survive successive generations, those links tend to die if people delete and redraw diagrams, since that results in a new GUID.
/Uffe
Schludi
Thank you very much that is exactly what i need!
