Author Topic: System Outputs for Search result not in Main Window  (Read 4690 times)
balu
« on: February 27, 2018, 10:03:30 pm »
Hello
Im using EAP 12.1
The search result appears normally in the main window. This was working fine.
But I have clicked something wrong and I´m not able to configure it back to the main window.
The System Output can be placed to all other places but not to the main window.
I found are suggestion here to use the DOCK to MAIN WINDOW button. But this button is not there.
Re: System Outputs for Search result not in Main Window
« Reply #1 on: February 27, 2018, 10:07:19 pm »
First do a search, and then from the second to last (menu)button choose the option "Dock in main View"
balu
« Reply #2 on: March 20, 2018, 08:36:18 pm »
Hello Geert,
thanks for responding. Unfortunately I was not able to solve the issue.
The Option "Dock in Main view" not appears.
We will switching to EAP v13.x soon. Then this issue will be fixed.
Thanks for helping
« Reply #3 on: March 20, 2018, 08:45:36 pm »
The options was there in v12.1 as well.
Nizam
  • Prolab Moderator
  • Model Sharing - Simplified
« Reply #4 on: March 20, 2018, 11:23:31 pm »
In most cases, applying a different workspace layout restores key windows back to position. Its worth to give it a try.
