Author Topic: Excel import MDG Office really slow?  (Read 5780 times)
Hurra
    • Find me at LinkedIn!
« on: February 28, 2018, 09:17:16 pm »
Hello!
I import 500 elements from an excel. My feeling it is reaaally slow.. about 1 hour or more.
Does it depend on my import profile or is this just the way it is? Can I some how optimize and speed up the import?
Robert
edit: working on a SQL repository through VPN connection
« Last Edit: February 28, 2018, 09:19:22 pm by RWHurra »
always learning!
Re: Excel import MDG Office really slow?
« Reply #1 on: February 28, 2018, 09:36:28 pm »
Hi RWHurra
Usually it wont take more than an hour for just importing 500 elements with main properties.
If you have mapped connector information in profile and checked multiple packages in Additional Packages to Look up section  then it will take some time to process and get the detail from selected packages.In that case too it won't take an hour for 500 elements.
Are you importing from Excel directly using the ribbon or importing from inside EA from extensions ?
Give a try directly from Excel Enterprise Architect Ribbon
BR
« Last Edit: February 28, 2018, 09:37:59 pm by Arshad »
Hurra
« Reply #2 on: February 28, 2018, 10:00:32 pm »
Thanks Arshad!
I have no connector information and not additional packages. I import directly in EA. Will try the EA ribbon next time!
always learning!
Hurra
« Reply #3 on: March 01, 2018, 08:51:06 am »
The import is still going strong like 12 hrs later...
always learning!
« Reply #4 on: March 01, 2018, 05:01:00 pm »
Hi RWHurra
Try sharing the profile which you created
Hurra
« Reply #5 on: March 01, 2018, 07:15:14 pm »
always learning!
« Reply #6 on: March 01, 2018, 07:25:00 pm »
Seems you've mapped some parent information in the profile.
Maybe cause of this the time exceeds.
Try importing it without mapping parent information in profile
Hurra
« Reply #7 on: March 03, 2018, 12:59:02 am »
Well, the parent information was important. The import is done hopefully I will not need to do it again. If I have to, I'll do it on a saturday then go back to sleep :D
always learning!
