Author Topic: Custom toolbox is not opening for diagram  (Read 4712 times)
Kristofer
« on: March 08, 2018, 11:13:10 pm »
Hi!
I have created an MDG Technology including custom stereotypes, diagram and toolbox, and imported this technology in a project. When creating a new diagram, I can select my custom diagram type, but when I open the diagram, the custom toolbox is not opened. I have to select it manually (so it is there and working).
I checked the xml file for the MDG:
<DiagramProfile>
<Property name="toolbox" value="NNN"/>
</DiagramProfile>
<UIToolboxes>
<Documentation id="3F040576-9" name="NNN" version="1.0" notes="My custom diagram"/>
</UIToolboxes>
It seems to be correct, but it is not working. Any ideas why?
Re: Custom toolbox is not opening for diagram
« Reply #1 on: March 08, 2018, 11:34:54 pm »
Hi Kristofer
Change the name of diagram profile stereotyped package with same name as toolbox and regenerate MDG .
or
A dirty fix is try changing the name property of documentation under DiagramProfile to NNN and check.
<DiagramProfile>
<Documentation   [b]name="NNN" [/b]version="1.0" notes=""/>   Give the tool box name here in diagram
</DiagramProfile>
<UIToolboxes>
</UIToolboxes>
« Last Edit: March 08, 2018, 11:38:28 pm by Arshad »
Kristofer
« Reply #2 on: March 08, 2018, 11:52:48 pm »
I started to play around with this and it seems that the problem is when you have a a profile element with the same name as the toolbox.
<UMLProfile>
<Stereotype name="NNN">
</UMLProfile>
<DiagramProfile>
</DiagramProfile>
<UIToolboxes>
</UIToolboxes>
It also worked to change the name property as you said.
