Author Topic: C# Add-In-TransformPackage, Import of Transform Templates and Code Templates  (Read 4988 times)
Tschana
Hello all,
First of all I want to mention that I'm totally new to EA.
I managed to program some basic tasks like adding some packages, create diagrams or to start the model transformation from a specific package using the TransformPackage function:
EA.Repository.GetProjectInterface().TransformPackage(string TransformName, string SourcePackage, string TargetPackage, string ExtraOptions);
My first question: can someone explain me what strings can be used for the "ExtraOptions"?
Secondly I didn't find a way to import a transformation template (which I exported through the "Export Reference Data"-Tool from EA). I searched for a method but didn't find one. Can you please give me a short example of how to import a transform template with C#. If it's possible to import a transformation template, are the modified templates like e.g. "File" or "Class" also updated?
And another question: Is the process for importing code templates (for generating source code) the same as for transformation templates?
Thanks in advance :)
The API is documented in the help : http://www.sparxsystems.com/enterprise_architect_user_guide/13.5/automation/project_2.html
In this case:
TransformPackage (string TransformName,
Boolean
Notes: Runs a transformation on the contents of a Package.
Parameters:
TransformName: String - specifies the transformation that should be executed
SourcePackageGUID: String - the GUID (in XML format) of the Package to transform
TargetPackageGUID: String - the GUID (in XML format) of the Package to transform into
ExtraOptions: String - enables extra options to be given to the command:
     -  GenCode=True/False - articulate code generation from the transformed elements;
        this option supercedes the current model setting
     -  SubPackages=True/False - specify if the child Packages are to be included whilst
        transforming a Package
Tschana
Thanks Geert for answering to my first question.
Do you have any suggestions for my other questions (import model and code transformation templates to EA through an ADD-In)?
Tschana
I just found a solution with the undocumented command CustomCommand:
Repository.CustomCommand("Repository", "ImportRefData", ExampleModelTransformation.xml);
Is it advisable to use the CustomCommand or is there any other way for importing special transformations via c#?
If there is a CustomCommand, that usually means there's no other way of doing it.
If there would be another way it woud probably be found on EA.Repository or EA.Project
