Author Topic: State: Select Composite Diagram not possible after Instance Classifier assigned  (Read 6314 times)
PeterHeintz
After having assigned a state machine via Instance Classifier to a state, it is not anymore possible to select a Composite Diagram to this state.
Remark: Same problem exist for actions later made to callBehavior
Seen in Build 1310 and others
Reported!
« Last Edit: March 14, 2018, 12:09:10 am by PeterHeintz »
Best regards,
Peter Heintz
PeterHeintz
Just realized that this problem has gone in V 14 Beta.
Best regards,
Peter Heintz
If so, I think it's a bug in the beta.
PeterHeintz
Oh my god! Regard it as a feature!
If you regard it as a bug, you have lots of bugs in this direction since years.
If you would fix them, my navigation facilitations for users would be gone.
From my perspective, an element having a component diagram, and double clicking on element to open any diagram are two distinct things.
Best regards,
Peter Heintz
I can't set a composite diagram on a submachine state in the beta anyway.
PeterHeintz
Hi Simon,
it seem I have more privileges than you!
Just create two state machines let’s say “Main” and “Sub”.
Insert a state in Main (e.g. State1).
Use context menu “New Child Diagram”/”Select Composite Diagram” on State1 to select the diagram under Sub.
And "voila”!
This works as long as you have not assigned a classier to State1, and from my opinion this should work if a classifier is assigned before as well (just because I belief this is a navigation feature).
Best regards,
Peter Heintz
