Author Topic: Retrieval of Report Constants of a Model Document under processing  (Read 3327 times)
Viking
I currently try to generate a report with Virtual Document. A Report Package has several Model Documents. Each document has the same Template assigned. In this template I want to retrieve a Report Constant (or a Tagged Value, if possible) of the Model Document, it is assigned to.
The current situation is as follows:
(1) The Report Generator uses the Report Constants from the Report Package for the Cover Page, which has been defined in the Report Generator.
(2) For the templates, used by the Model Documents, the Report Constants stay empty. I do not know which Report Constants get retrieved.
My questions are:
(1) which Report Constants are used by the template under processing? As I said, they stay always empty.
(2) is there a way to retrieve Report Values of the Model Report currently under processing?
Many thanks in advance, V.
