Author Topic: Query Builder Object.Name contains Search Term?  (Read 5286 times)
AndyJ
  • It's only a model
« on: December 13, 2011, 11:35:15 am »
Hi people,
I'm fiddling around trying to see if I can build a custom search to use EA as a "Data Dictionary"
The following SQL works fine, but I'm hoping to find a method to return a match if the search term is contained within the Object.Name.
Can anyone suggest a method?
I've tried putting wildcards in the Search Term box, and tried
'<Search Term>'IN(t_object.Name) but haven't lucked onto a solution yet.
As an example, I'd like the search term "Order" to return "Sales Order" and "Order Profile".
The current SQL is provided for info.
Andy
SELECT t_attribute.ea_guid AS CLASSGUID, 'Attribute' AS CLASSTYPE,
t_object.Name as Table_Name,
t_object.Tagged,
t_attribute.Name,
t_attribute.Notes,
t_objectproperties.Property,
t_objectproperties.Value
FROM t_attribute, t_object, t_objectproperties
WHERE t_attribute.Object_ID = t_object.Object_ID AND t_object.Object_ID=t_objectproperties.Object_ID AND t_object.Name='<Search Term>'
Re: Query Builder Object.Name contains Search Term
« Reply #1 on: December 13, 2011, 11:53:36 am »
Try this:
AND t_object.Name LIKE '#WC#<Search Term>#WC#'
EA will replace #WC# with the correct wildcard character for the database you're using ('*' for MS Access/EAP files, '%' for everything else).
« Last Edit: December 13, 2011, 11:56:47 am by KP »
AndyJ
  • It's only a model
« Reply #2 on: December 13, 2011, 01:13:01 pm »
Nice!
Andy
