Author Topic: "Set as model default" does not appear  (Read 28229 times)
HansAdmiraal
    • Admiraal IT
« on: March 20, 2018, 01:59:22 am »
I can't find the option "Set as model default diagram" in the EA 13.5 trial version (build 1352, ultimate edition).
In the diagram context menu, I can see "Set as User Default Diagram", but that's not what I want.
Despite the information in the user guide, "Set as model default diagram" is not present in the diagram context menu, not even in the Advanced submenu, nor in the menu bar (Design -> Diagram -> Manage).
Is it possible to have a model default diagram in EA 13.5?
« Last Edit: March 20, 2018, 02:06:25 am by HansAdmiraal »
Re: "Set as model default" does not appear
« Reply #1 on: March 20, 2018, 02:07:20 am »
Hans,
It is definitely possible, but IIRC only via the ribbons menu.
In v14 this is found in Layout | Diagram | Manage | Set as Model Default
elr
« Reply #2 on: May 07, 2026, 12:15:36 am »
Hello Geert
Do you know where now this option is hidden because on v.17.1 it does not appears on Layout/Diagram/Manage menu...
Thank you.
Eric
elr
« Reply #4 on: May 07, 2026, 04:33:44 am »
Thank you !
