Author Topic: Add-In : How to add Object Diagram (C#)  (Read 5186 times)
The apprentice
« on: April 06, 2018, 06:46:21 pm »
Hello
I try to add a new Interface in my Class Diagram with the Add-In on Visual Studio.
According to this example : https://www.sparxsystems.com/enterprise_architect_user_guide/9.3/automation/addandmanagediagrams.html
I have this :
EA.Package toto;
            toto = EaRepository.GetPackageByID(1);
            EA.Package package = (EA.Package)toto.Packages.GetByName("Use Case Model");
            EA.Diagram diagram = (EA.Diagram)package.Diagrams.AddNew("Logicial Diagram","Class");
            diagram.Update();
            EA.Element a = (EA.Element)package.Elements.AddNew("ReferenceType", "Interface");
            a.Update();
            //this cause the error in Enterprise Architect
            EA.Element o = (EA.Element)diagram.DiagramObjects.AddNew("test", "Interface");
            // o.ElementID = a.ElementID is impossible due its protection level so I tried this :
            o = a;
            o.Update();
            diagram.Update();
I have my new diagram and my new interface but I want insert the interface into the diagram.
But I have the following error :
"EA_MenuClick : Unable to cast COM object of type 'System._ComObject' to interface type 'EA.Element'. This operation failed because the QyeryInterface call on the COM component for the interface with IID'{xxxxxx-xx-xx-xxx-xxx}'failed due to the following error : (Exception from HRESULT : 0x80004002(E_NOINTERFACE))."
How to do ?
Please forgive my english, Thank you.
Re: Add-In : How to add Object Diagram (C#)
« Reply #1 on: April 06, 2018, 07:19:59 pm »
should be
EA.Element o = (EA.Element)diagram.DiagramObjects.AddNew("l=10;r=110;t=-20;b=-80", "");You can probably guess the meaning of the first parameter.
You then need
o.ElementId = a.ElementId;
a.Update();
(my C# is, well, not present...)
« Last Edit: April 06, 2018, 07:22:18 pm by qwerty »
The apprentice
« Reply #2 on: April 06, 2018, 07:47:16 pm »
The coordinates of the interface I guess.
It doesn't work, I have the same error.
You then need
a.Update();
I can't do this because the attribute ElementID is private ( impossible to create a setter)
Thank you.
« Reply #3 on: April 07, 2018, 03:09:01 am »
Then it's likely a C# issue (which I'm not fluent in). You need to wait for the language gurus to help you out.
« Reply #4 on: April 07, 2018, 03:59:52 am »
The problem you are having (you should always include the actual error message) is because you are trying to cast an EA.DiagramObject to an EA.Element
Something like this should work a lot better.
var diagramObject = (EA.DiagramObject)diagram.DiagramObjects.AddNew("l=10;r=110;t=-20;b=-80", "");
The apprentice
« Reply #5 on: April 17, 2018, 11:00:27 pm »
It Works, Thank you.
