Author Topic: Diagrams getting chopped when generating documentation from 13.5 on Windows 10  (Read 3994 times)
jankari
I just started using 13.5 on Windows 10. When I generate documentation the diagrams are getting chopped at a certain size. The type of diagram or the output format has no bearing. The same thing happens if I go to the diagram, select all elements and copy, and paste it in a Microsoft Word document. The exact same version and model works fine on Windows 7.
Has anyone else come across this, and any solution?
Thank you in advance for your time and knowledge.
Sunshine
  • Its the results that count
Weird, I've had the opposite where an extra margin of space in the image of around 15% of diagram width is created on right hand side. Seemed to be random and could never find the cause.
What part is getting chopped in your diagram?
In the past to control the size of the diagram being created in docs I've added a boundary to the diagram, coloured it white and sized it to control the diagram width and height kind of like a frame.
Happy to help
jankari
I have found a solution. The following fixes it:
1.       In “Display Settings” > “Change the size of text, apps, and other items”, set it to 150% ( in my case, at resolution of 1920 x 1080).
2.       Check the “Mark this my main display” checkbox, if using multiple displays with the setting of “extend these displays”.
