Author Topic: Log file from XMI import  (Read 5838 times)
« on: April 13, 2018, 12:51:00 am »
There's a check mark "Write Log File" in the XMI import dialog. Fine! But where the hell is that log written???
Nizam
  • Prolab Moderator
  • Model Sharing - Simplified
Re: Log file from XMI import
« Reply #1 on: April 13, 2018, 10:30:11 am »
From the help
The log file is saved in the directory from which the file is being imported, with the same name as that of the imported file plus the suffix _ import.log.
« Reply #2 on: April 13, 2018, 03:44:46 pm »
You are right. I overlooked that since the im-/export dialog restricts display to .xm* files (as an Apple user I'm used to see other files greyed out; hum - Windoze). Anyway, the log just tells me that everything is find while the import croaks with an error. And after close/open EA everything is imported. Time for a new bug report :-/
« Reply #3 on: April 13, 2018, 04:39:44 pm »
Sparx has a conceptual problem with "logs".  They obviously didn't didn't watch Startrek (especially series 1).  Logs are to be written in real time and with a timestamp.  Otherwise, they aren't logs!  (That's why the show is interrupted with the log (to make the log)).
« Reply #4 on: April 13, 2018, 06:43:17 pm »
Yep. Like they have no test department. Or someone to design a useful GUI. Sigh. Let's see what my bug report brings in return. I suspect "It's a feature, not a bug".
« Reply #5 on: April 19, 2018, 07:00:52 pm »
I imported the XMI with ArgoUML and that immediately showed where the culprit with my XMI was. No (further) comment.
