Author Topic: 'Link' Connector type - did I imagine it ?  (Read 6295 times)
Ian Mitchell
« on: April 16, 2018, 11:10:58 pm »
I'm (fairly) sure that there used to be a Connector Type of 'link', which UML says (or at least, used to say) we're supposed to use to connect Instances with each other.
The element/element relationship connector type defines what the instance/instance connection means, but I thought that the instance/instance connector itself was just a 'link'.
Did I imagine this?
It seems that in V14 (and I think 13 as well) I seem to have to lost the ability to create a simple link.
@Sparx - was this deliberate? Maybe a new corner of UML which I missed? Or maybe it got lost?
And, if I just add 'link' to t_conectorTypes, is that allowed? Feels like a big step, inventing new Connector Types, which might have bad consequences.
www.eaDocX.com
www.theartfulmodeller.com
Uffe
Re: 'Link' Connector type - did I imagine it ?
« Reply #1 on: April 17, 2018, 12:12:46 am »
Hi Ian,
There are Links, and you can connect two Objects with one, in 13.5.
/Uffe
« Reply #2 on: April 17, 2018, 09:54:04 am »
Hi Ian,
IIRC, Links are instances of Associations.  As you say, they are used to link a specific instance (of a classifier) to another specific instance (of another, possibly the same, classifier).
I guess you could also use stereotyped versions to handle aggregation and composition links.
« Reply #3 on: May 07, 2018, 11:02:47 am »
I think it's always been the case that a Link is represented internally in EA as Connector_Type='Association'. If the two ends are instances then by duck typing it's an Association instance (aka Link).
Ian Mitchell
« Reply #4 on: May 08, 2018, 06:22:53 pm »
Thanks @KP  - good to know how to (probably) make things backwards compatible. Could we have a note somewhere in the final V14 documentation to say that this has changed?
www.eaDocX.com
« Reply #5 on: May 09, 2018, 08:33:51 am »
Nothing has changed. Except possibly the labels in the quicklinker (used to say "Link" or "Directed Link", now says "Association", but they're all Associations).
