Author Topic: Generating several toolbox profiles from one EA file with shared stereotypes.  (Read 3576 times)
r2
Hello all,
I have a profile file containing several toolbox profiles (each with an own diagram). The toolboxes share identical stereotypes and they will be used in the same model. When applying the toolbox elements in the actual model, do I encounter any issues in the long run? (since I have applied identical elements from different toolboxes in the same model)
To be clear,
You have
- A regular UML profile with "real" stereotypes
- Multiple toolbox definitions that use some of these stereotypes.
That is perfectly fine and won't be a problem. You can even use standard UML elements or stereotypes from other MDG's in your toolbox.
