Author Topic: Time-aware MDG Technology models  (Read 5957 times)
Uffe
« on: April 19, 2018, 09:39:55 pm »
Hi all,
So I'm thinking about trying time-aware models in my MDG Technology project, where I've got a couple of different technologies.
Let's say I've got a model that I've generated an MDG Technology from, and I clone that model.
If I now generate a profile from a package in my cloned model, going from the project browser and not the diagram, will the generated profile include the non-cloned elements?
Will the generated profile have the same "<Documentation id" attribute as the original?
/Uffe
Uffe
Re: Time-aware MDG Technology models
« Reply #1 on: April 19, 2018, 10:10:58 pm »
... No it won't, and no it won't.
/U
« Reply #2 on: April 20, 2018, 10:10:52 am »
/U
Thanks for the "heads up".
As per my reply to the Import/Export topic, I suspect it's working correctly (at present).  I'll have a look (when I get a minute or two) to better understand your point.
Uffe
« Reply #3 on: April 20, 2018, 04:52:26 pm »
Hi Paolo, and thanks for taking the time. I was hoping you would. :)
MDG Technology development is my use case for time-aware exports. Rather than using the diagram's context menu item to generate a profile (which isn't an XMI export, but still an export of sorts) I've always used the project browser's.1
Being able to maintain TAM-style version-controlled MDG Technology models would be useful, but it would require that profile generation from cloned models included the non-cloned elements.
I should mention here that I haven't tested generating a profile from a TAM-cloned diagram, which might well work. My overall point is that the TAM functionality should be better integrated, and the generate-profile-from-browser function is an example of how it isn't.2
/Uffe
1There was something that didn't use to work when you used the diagram's menu. I can't remember what now and I don't know if it's ever been resolved but the two menu items did not yield the same result (!) (!!) (!!!!) (why isn't there an emoji with its hair on end?) so I went with the one that worked for me.
2Also I'm pretty much making this up as I go.
« Reply #4 on: April 20, 2018, 05:05:03 pm »
I use the generate from project browser as well, first and foremost because I don't want to depend on what is visible on a diagram for my exports.
I don't consider diagrams to be a "real" part of the model and don't like to depend on them for this type of stuff.
Uffe
« Reply #5 on: April 20, 2018, 06:49:05 pm »
Yes, and I agree with you, but there was also something that specifically didn't work when you exported from the diagram. Wish I could remember what.
OTOH, if you want to reuse a toolbox page between toolbox profiles you've got to export from the diagram. Unless they've done something with that in recent versions?
/Uffe
« Reply #6 on: April 20, 2018, 06:53:14 pm »
/Uffe
I don't do that anyway, so that is not really an issue for me.
I guess I would even prefer to duplicate the toolbox page over using diagrams.
