Author Topic: Language in activity parameters and action pins  (Read 3623 times)
Uffe
« on: April 25, 2018, 06:58:30 pm »
Hi all,
When you create an activity parameter in a diagram, the parameter's Language property is set to the project's default regardless of the corresponding properties in the diagram and the activity.
If you create the parameter in the Structural Elements dialog, the behaviour is the same.
The behaviour is also the same for action pins in actions, both when created from the toolbox and in the Structural Elements dialog.
When an action pin is created as the result of instantiating an activity with paremeters, the pin is likewise given the project default Language.
When an activity parameter is created, its Language should be set to the same as its parent activity's.
When a pin is created manually, its Language should be set to the same as its parent action's.
When a pin is created as an instance of a parameter, its Language should be set to the same as the corresponding parameter's.
Reported.
/Uffe
