Author Topic: Restrict specific scripts based on which group a user belongs to  (Read 4274 times)
rupertkiwi
Is it possible to restrict specific scripts based on which group a user belongs to?
In a similar way that diagrams or packages can be locked depending on which group a user is a member of?
I can restrict the running and editing of all scripts based on a user's group via the Security Group settings but it would be good to restrict individual scripts
Rupert
Re: Restrict specific scripts based on which group a user belongs to
« Reply #1 on: May 02, 2018, 03:47:07 pm »
Hi Rupert,
Not out of the box, but you can of course test the current user in your script yourself, and refuse to execute if she doesn't meet your requirements.
rupertkiwi
« Reply #2 on: May 02, 2018, 04:05:58 pm »
OK, thanks Geert for your prompt reply.
I will have a play around and see how I go
Cheers,
Rupert
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
« Reply #3 on: May 03, 2018, 04:41:12 am »
Use the following function in JScript-type script and validate it in the logic of your script:
function isUserInGroup(groupGUID) {
var userGUID = Repository.GetCurrentLoginUser(true);
var result = DBGetFieldValueArrayString("GroupID", "t_secusergroup", "UserID = '" + userGUID + "' AND GroupID = '" + groupGUID + "'");
if(result.length == 0) {
return false;
return true;
