Author Topic: Problem with Update method  (Read 20529 times)
bilon
« on: May 03, 2018, 12:02:22 am »
I have simple script changing single property of elements attribute and subsequently iterating through elements attributes to display the new value. But the old value is displayed. Here is the script:
Sub Main
   Dim tab AS EA.Element
   Dim col AS EA.Attribute
   For Each tab In Repository.GetTreeSelectedElements
      For Each col In tab.Attributes
         If col.Name = "TABLE_NAME" Then
            Select Case col.Type
               Case "varchar"
               col.Type = "char"
               col.Update
               Session.Output "1: " & col.Name & " " &  col.Type
               '1: TABLE_NAME char
            Case Else
            End Select
         End If
      Next
      'tab.Attributes.Refresh
            Session.Output "2: " & col.Name & " " &  col.Type
            '2: TABLE_NAME varchar
         End If
      Next
   Next
End Sub
The new value is correctly saved to model, so why it is not displayed in the script?
Re: Problem with Update method
« Reply #1 on: May 03, 2018, 12:17:46 am »
You need a Refresh of the collection in between the 2 loops.
bilon
« Reply #2 on: May 03, 2018, 07:41:56 pm »
As you can see, Refresh is already there. But commented, because it doesn't help.
Uffe
« Reply #3 on: May 03, 2018, 08:47:32 pm »
I think you need to
    tab.Refresh()
as well.
Quote from: User Guide link=https://www.sparxsystems.com/enterprise_architect_user_guide/13.5/automation/element2.html
Notes: Refreshes the element features in the Project Browser.
Usually called after adding or deleting attributes or methods, when the user interface is required to be updated as well.
/U
« Reply #4 on: May 03, 2018, 10:39:12 pm »
I might be wrong, but the refresh.line seems to be commented out.
Uffe
« Reply #5 on: May 04, 2018, 05:12:04 pm »
Yes, but he's refreshing the Collection, not the Element. According to the API documentation, you need to refresh the element after adding attributes.
/U
« Reply #6 on: May 04, 2018, 06:46:50 pm »
I shouldn't lean in too much without testing, but refresh is to update a collection. He's changing elements of a collection and you need to tell EA to get the updates since it's using a cache of the old values. Since the refresh is commented in his code, this must be the culprit.
bilon
« Reply #7 on: May 04, 2018, 11:31:00 pm »
The reason why tab.Attributes.Refresh is commented, is, that tested it but it didn't work, so I commented it. Even tab.Refresh doesn't work!
« Reply #8 on: May 05, 2018, 01:14:57 am »
Well, I just ran your script and it worked with NO issues.
Uffe
« Reply #9 on: May 07, 2018, 08:00:28 pm »
I know, but it's implemented by other classes as well, and the user guide (as quoted in my first post) explicitly states that you need to Refresh() the Element itself after adding attributes.
.... and that's the end of this argument. :)
/U
bilon
« Reply #10 on: May 10, 2018, 10:22:59 pm »
What do you mean with "worked with no issues"? Does it mean, that the output looked like this:
1: TABLE_NAME char
2: TABLE_NAME char
« Reply #11 on: May 11, 2018, 12:20:40 am »
Lucky you, it was still in my output window:
1: TABLE_NAME char
1: TABLE_NAME char
(output from 2 runs).
bilon
« Reply #12 on: May 16, 2018, 01:01:18 am »
In this case, it isn't definitely without issues. The issue is, that after setting datatype to "char" in step 1, it is displayed as "varchar" in step 2. They should be same.
« Reply #13 on: May 16, 2018, 04:36:44 am »
Ah, now I see. Unfortunately you reply here in long distances so I'm out each time. I see that the 2nd loop shows the non-updated values. But EA is doing the change (this is why I posted that it works correctly) since afterwards the types ARE changed. So the question is: why does the 2nd loop show the wrong values. Hmm. Tricky indeed.
« Last Edit: May 16, 2018, 06:06:26 pm by qwerty »
« Reply #14 on: May 16, 2018, 04:55:39 am »
Replacing the 2nd loop like this
     dim tab1 as EA.Element
     set tab1 = Repository.GetElementByID(tab.ElementID)
     For Each col In tab1.Attributes
         End If
      Next
fixed the issue. Honestly, I never ever used a collection more than once. This Refresh-thingy is just fishy in my opinion. And obviously it's broken too. Feel free to send a bug report.
P.S. Probably the Refresh has only an effect if you added or removed elements from it. In any case it's broken.
« Last Edit: May 16, 2018, 06:09:46 pm by qwerty »
