Author Topic: Convert a requirement to a <<Block>>  (Read 4184 times)
DanaMaxwell
« on: May 07, 2018, 10:46:49 pm »
I have access to a SWBS in a Doors Module and would like to import it as a SWBS. Problem is, when importing from DOORS it will only create requirements. Is there a way to convert the elements to <<Blocks>>?
PeterHeintz
Re: Convert a requirement to a <<Block>>
« Reply #1 on: May 07, 2018, 11:00:28 pm »
Design/Element/Manage/ChangeType should allow you to convert it to a class. Afterwards you can assign e.g. sysml:bock stereotype.
Best regards,
Peter Heintz
Nabil
    • View My LinkedIn Profile Here
« Reply #2 on: May 07, 2018, 11:18:03 pm »
As you have mentioned you are trying to import.
Writing a script to convert will work for bulk convert
You can refer local scripts -> manage element extras.
Even you can export to excel and import as block using MDG office
Nabil
DanaMaxwell
« Reply #3 on: May 08, 2018, 03:29:55 am »
Thanks for the tip.
I am using VB and am looking at a hierarchy of requirements. On a given element I am getting IsLeaf False which makes sense because I know there are other requirements below it on the structure (I can see/navigate to them in the browser) but I cannot find Elements, Requirements or RequirementsEx. Count is = 0 for all three? How do I navigate down to these requirements?
« Reply #4 on: May 08, 2018, 05:31:44 am »
How are they connected? Through hierarchy? Then use Element.Elements to get the collection of contained elements. If the are associated use Element.Connectors to find the related elements via the connectors.
