Author Topic: EA14 Connector Properties Dialog Box Doesn't Commit Changes  (Read 5265 times)
dnemiro1
In EA13 (and previous versions) the sequence diagram connector properties was not-dockable and had a typical Ok/Cancel button.  EA14 doesn't seem to have this and after changing a property of a connector (e.g. from async to sync) nothing happens until you select another connector in the diagram.   If there is no other connector in the diagram, nothing happens.
Is there a way to get back to EA13 mode for the connector dialogs?
Nizam
  • Prolab Moderator
  • Model Sharing - Simplified
Re: EA14 Connector Properties Dialog Box Doesn't Commit Changes
« Reply #1 on: May 11, 2018, 10:47:20 am »
Interesting, You seem to be touching the edge cases in EA 14, sequence connector dialog in the new form seems quite interesting
  • I change a property (say synchronous) and click elsewhere and it says, Unsaved Property Changes and prompts me to save, where there is no save button :D
  • I couldn't get the vertical/horizontal scroll in the window, I have to pop it out and make it big enough to see the details
dnemiro1
« Reply #2 on: May 12, 2018, 12:19:59 am »
I'm surprised Sparx didn't see this earlier.  All it takes is the creation of a new sequence diagram.
Do you know if there is a way to get back to EA13 mode?
thanks,
DN
