Author Topic: Handling of receptions with transformation templates in EA14  (Read 3277 times)
Tschana
Hello all,
I just found out that with EA14 it is possible to add signals to a class or interface with the element context menu optoin: Feature & Properties | Reception.
Does somebody know how to access the registered receptions of a class/interface during PIM to PSM transformation? I didn't find any transformation template for it.
As an example I’m trying to reach following behavior: I have an interface called "Interface A". This interface has signals (named "Signal1" and "Signal2") as receptions. I would like to create some classes based on the names of the signals which are registered as receptions in an interface. This means that after transformation there still exist the interface "Interface A" and a class called  "Signal1" and another class called "Signal2" are created.
Thanks in advance and best regards,
Tschana
Tschana
Re: Handling of receptions with transformation templates in EA14
« Reply #1 on: May 24, 2018, 10:38:36 pm »
Answer from Sparx Support:
This has been confirmed as an issue and lodged for correction in a future build of EA.
