Author Topic: Block Definition Diagram - Summing a value from part association blocks  (Read 6380 times)
DanaMaxwell
I am creating a Block Definition Diagram in order to model a system hierarchy. One of the goals is to track the sum of some properties of the parts, for example weight.
Leaf nodes would have a weight value while moving up the hierarchy would result in a sum of the weights of the aggregate parts.
Ideally, I would track both a weight and a budget weight at each level and flag the user when a budget has been exceeded (or run a report to find where weight budgets have been exceeded).
So, where and how do I record the weights (attributes, properties,...)?
How do I get the tool to sum the values based upon the part association?
Would be happy to get a pointer on where to find this in the documentation.
PeterHeintz
Hi Dana,
to store your weights I would uses tagged values.
For the calculation you need to write a script, you have to call maybe from time to time.
Best regards,
Peter Heintz
DanaMaxwell
Why would you choose tagged values as opposed to attributes or properties? I would like to be able to see the values on the block in a block diagram.
I like attributes because I can define all my the aspects I wish to track (weight, volume,...) as attributes is a block and then have all the rest inherit.
Pros/cons to each approach?
« Last Edit: May 16, 2018, 12:56:11 am by DanaMaxwell »
PeterHeintz
you could do it with attribute as well.
I personally would us tagged values, because by doing so, it is easy to define a stereotype having those tags. And by assigning the stereotype to a block or property you get the tags created by EA.
Depending on your kind of element it is possible to see the tags in the diagram as well.
Best regards,
Peter Heintz
DanaMaxwell
"Depending on your kind of element it is possible to see the tags in the diagram as well."
Can you elaborate? How would I go about having the Tagged Value visible in the <<Block>> of a Block Definition Diagram. Assuming that I extended <<Block>> to <<myBlock>>.
PeterHeintz
Use "Feature and Compartment Visibility".
Best regards,
Peter Heintz
DanaMaxwell
Thanks!
