Author Topic: Request: More flexibility in diagramm zoom  (Read 27236 times)
PaulV
« on: May 15, 2018, 06:34:31 pm »
Nice to have:
  • Save currently set zoom as persistent zoom.
  • Set an arbitrary zoom (probably restricted to an reasonable range).
Re: Request: More flexibility in diagramm zoom
« Reply #1 on: May 15, 2018, 06:55:03 pm »
Hi
Persistent zoom is available from EA 13.
Layout > Diagram > Persistent Zoom .
Please have a look Pan and Zoom
PaulV
« Reply #2 on: May 17, 2018, 12:08:15 am »
Hi
I did mean the option to save an arbitrary zoom level, not only one from the fixed set {75, 100, 150, 200}%.
mateiacd
« Reply #3 on: June 10, 2021, 03:37:05 am »
Actually you are able to set the diagram zoom level to an arbitrary value (for example let's say ~ to 115%)
See this page for details:
https://sparxsystems.com/enterprise_architect_user_guide/13.0/modeling_tools/appearance_options_diag.html
Try like this:
- Use Ctrl+mouse wheel to zoom in a little bit more than 100% (say ~ to 115%)
- Then from the ribbon, select Design -> Diagram -> from the Manage dropdown list -> Properties
- In the dialog click Diagram.
- Finally click the "Set as Default" button
Then each time you will open the diagram, you will see that the zoom level you've set will be respected.
« Last Edit: June 10, 2021, 03:39:20 am by mateiacd »
