Author Topic: Auto Name Counters shared by 2 Types  (Read 4673 times)
rtenkaten
« on: May 18, 2018, 04:07:26 pm »
Is it possible to set up 1 Auto Name Counters (i.e. Alias) that will be shared/ count up for 2 Types (i.e. "Requirements" and "Features").
Nizam
  • Prolab Moderator
  • Model Sharing - Simplified
Re: Auto Name Counters shared by 2 Types
« Reply #1 on: May 18, 2018, 04:15:09 pm »
Not in the 'out of box' solution. Can be custom-implemented though.
However one of the limitation (not possible to support different counters for different stereotypes) could be used to your advantage if you are using two different stereotypes of same type. (e.g. different type of requirements)
Guillaume
    • www.umlchannel.com
« Reply #2 on: May 31, 2018, 12:32:59 am »
As a workaround you can define all your elements first, then place them on a diagram (in the order from top to bottom or left to right), and use eaUtils Generate Alias feature.
More info available from http://www.eautils.com/en/help/itemlist/category/17-generate-alias-values-help-section
Hope it helps.
Guillaume
