Author Topic: How to get connector tagged value within a stereotyped code generation template?  (Read 3740 times)
camel2
Hi there,
I've got a question on the EA code generation using code templates and stereotypes:
I've got two different custom stereotypes applicable to functions. One of them also has a connector tagged value which can be set to a function with the other stereotype.
What I mean:
<<Stereotype A>> connectorTaggedValue=function2()
function1()
<<Stereotype B>>
function2()
Now I created a stereotyped template for code generation, which handles Stereotype A. Is there any possibility to get the name of function2(), which is stored in the tagged value? I tried %opTag:"connectorTaggedValue"%, but it only returns some kind of reference, like {E744F61F-FABD-492f-892C-93A0AD6B4527}, and I'd like to have the string "function2" instead.
Any ideas? :-)
Ann
Nizam
  • Prolab Moderator
  • Model Sharing - Simplified
You are using a REFGUID Tagged value, and the RefGUID stores the GUID of the referenced item as its value. which then requires another step to get the actual item.
When I used to work on this I used to have a addin which will return me the actual item (element, or attriabute or operation) based on the GUID i get from this, and use that in my code templates.
PS - Have to check if there is any other way that allows me to get the value from code templates
camel2
Thank you very much, that already helps me a lot!  :D
