Author Topic: [DOC] Element atributes using Connector  (Read 7529 times)
r4ph4e1
« on: May 22, 2018, 10:56:14 pm »
Dear all,
i'm looking for way to get details of connectors in documentation.
In my case i've diagram with actor and use case.
I have to get in table in one row name of actor, notes of actor and name of use case
I was also try to use template fragments but EA always devide tables
Could anyone tell me how to improve it? For now I have as in the picture
https://ibb.co/kWzky8
Nizam
  • Prolab Moderator
  • Model Sharing - Simplified
Re: [DOC] Element atributes using Connector
« Reply #1 on: May 22, 2018, 11:00:38 pm »
Insert a table with 3 columns  in the <element element> section, one for name, one for notes, click on the third column and enable Connector, you'll insert the <connector connector> tag in the third column, in this you can enable the connector->source->Element or connector->target->Element
r4ph4e1
« Reply #2 on: May 22, 2018, 11:27:05 pm »
my description was not full :)
i'm sorry
in the screen i attached in url as You can see i need to open source>element in one cell, and finish these section in the same cell.
I want to use the source.element in 2 cells (one with name and second with descritpion).
In attached images in the second column i have for now connector.name but i want to have in this place source>element>notes
Nizam
  • Prolab Moderator
« Reply #3 on: May 23, 2018, 10:12:50 am »
For more flexibility, such as what you are after, please consider introducing a fragment (SQL) to fetch the right fields and render them in a table.
