Author Topic: Document Generation; How to render Events of Tiggers  (Read 5555 times)
PeterHeintz
« on: May 23, 2018, 12:24:59 am »
I have within a uml.trigger, defined a Signal specification. Now I want to show this trigger specification in my generated document. To do that, I tried to user the Event section in the document template but nothing is generated.
What template section is right to handle the trigger specifications?
Best regards,
Peter Heintz
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
Re: Document Generation; How to render Events of Tiggers
« Reply #1 on: May 23, 2018, 01:53:10 pm »
As it seems there is no way to include triggers in the template editor, you can explore the database in order to determine how your triggers are stored. Then, you can do a Document fragment to get the information of you trigger via an SQL. After that, just include your fragment into your document.
RoyC
  • Read The Help!
« Reply #2 on: May 24, 2018, 10:57:19 am »
I think you would render an event of Tiggers as having a top made out of rubber and a bottom made out of springs...
(And pay due reverence to the combined work of A A Milne and Walt Disney.)
Best Regards, Roy
« Reply #3 on: May 24, 2018, 04:11:59 pm »
and it's not yet Friday!  8)
PS you can also use them for ArchiMate Zebedees...
« Last Edit: May 24, 2018, 04:14:57 pm by Paolo F Cantoni »
PeterHeintz
« Reply #4 on: May 24, 2018, 04:40:25 pm »
Yes, I mean triggers and not the tiggers, and I to want render events assigned to them.
How can I do that?
Best regards,
Peter Heintz
PeterHeintz
« Reply #5 on: May 26, 2018, 12:05:46 am »
Is there anyone who knows if it is possible to render events assigned to trigger on documents without scripting, and if so how?
Best regards,
Peter Heintz
« Reply #6 on: May 26, 2018, 12:54:59 am »
I don't think you need scripting, but you will probably need an SQL fragment as previously suggested.
