Author Topic: Is a combination of list macro and calling templates with parameters possible?  (Read 3804 times)
Tschana
Dear Community,
calling user defined templates is possible with the list macro or simply by calling a template.
With the list macro it is possible “to loop or iterate through a set of Objects that are contained within or are under the current object” (quote from software-models.pdf).
%list=”Class__MyTemplate” %
If I simply call a template it is possible to add parameters to it (but EA isn’t looping through the child elements):
%Class__MyTemplate ($className)%In Class__ MyTemplate I can use e.g.
$example=$parameter1 which I would need for doing some if-else queries.
Is there any opportunity to combine these two methods so that I can loop through objects and also pass a parameter to it?
Best regards and thanks in advance,
Tschana
ea1020
Thank you for the sample code
