Author Topic: BPSim: Assign Resource to SubProcess  (Read 3625 times)
umbra
« on: May 25, 2018, 07:20:20 pm »
I'm trying a simple BPMN process:
StartEvent1->Task1->SubProcess1->EndEvent1
enlarged SubProcess1:
StartEvent2->Task2->Task3->Task4->EndEvent2
The whole Subprocess needs one Resource1. I assign Resource1 to the Subprocess1 but it gets ignored in the simulation (e.g. no token waits till resource is available).
I can't attach the resource to each element in the Subprocess1 (Task2->Task3->Task4) because the tasks are processed one after another and should keep one resource the whole time.
I need a solution to make it work to attach the resource to the subprocess or a solution for attaching a resource from task2 and keep it till the end of task4.
I would be very grateful for any feedback on this topic.
Thank you!
Edit: Build1421
« Last Edit: May 28, 2018, 06:53:03 pm by umbra »
BPSimNovice
Re: BPSim: Assign Resource to SubProcess
« Reply #1 on: May 14, 2020, 12:44:18 pm »
I am facing this problem as well.
I would like to assign a resource to a sub-process consisting of 2 activities.
The resource should not be released unless it finishes the sub-process.
Anyone had any ideas on how to get this working or is there another method to assign resources?
Thank you.
